There are notches at the top of the intake ports on the EFI heads that don't exist on the non EFI heads. The EFI manifold might be a direct bolt on to the E31/E88 head that is likely on your 240Z engine but would not work without those notches.
... I knew about the performance loss but it would be better than no motor I guess.
"no motor" should not really be considered an alternative in Idaho - lots of L28's in Idaho.
Tell the guy looking for an L28 to call
Idaho Z Car
2913 Garrity Blvd.
Nampa, Idaho 83687-3629
(208) 466-0004
FWIW,
Carl B.
