  • 6 months later...
I was fortunate to have Mr. K himself autograph my 240's glovebox door with a silver Sharpie marker. I then clear coated the door with acrylic spray to preserve the signature. It looks great, is permanent and does not make the door appear any different from the rest of the dash.
The silver Sharpie can also be used in other areas such as the choke plate to restore the factory finish. Be aware that if it is not clear coated, it will eventually wear off.
I'm pleased with the way it turned out but will see how long it lasts before I do the dash and glove box. I knew I should of taken photos before and after. :stupid:
Bonzi Lon
I'm thinking about doing it as well with shoe polish.
I still have a crack free dash in my Z, but it is dull now. I've tried many stuffs on it without much success.
6 months is not a long period of time but I'll be curious to know how everything looks now.
[Edit]: I've just seen the other post about the same kind of topic and I got my answers :)
Edited by Lazeum
  • 2 months later...
In the process of replacing the center gauge bulbs, and upgrading to the Honda blower motor, I decided my glove box door could use a little touching up.
I didn't have a silver sharpie on hand, but I did have a silver Testors Enamel Paint Marker that I've used for a lot of other projects.
The first two pictures show the glove box door as it was when I removed it. From the looks of the original, it doesn't seem to have been "chrome" to begin with, but then again, it was pretty beat up.
The last three pictures show the result. I didn't do a perfect job on the first pass. Having used this marker for a lot of other stuff, the tip was a little bit ragged, which led to a little paint going where I didn't want it to. I tried to use a black sharpie to cover up the "overspray," but of course the sharpie didn't make a true black... more like a dark purple.
My fix is easily visible under the right light and at the right angle, but I'm not too worried about my passengers noticing in any lighting condition I've ever seen in my car.
In retrospect, a silver sharpie would have been easier to control, and I'll definitely pick one up to try on other trim jobs I have yet to do. The rest of the glovebox door is pretty faded, and could use a little love, but that can wait for another time. I'm more bothered by the warped shape of the inner and outer door surfaces (from that silly little glove box light plunger - doesn't even work anymore!).
Edit: added an installed picture. Keep in mind this was with the flash, so it really brought out all the weird color fading going on with my glove box door. The radio and wiring are all pulled out because I dropped a bulb down from the center gauges, and had to go looking for it :stupid:. Couldn't stand the thought of a piece of metal floating around back there
Edited by Inf
just wanted to add my praise for the silver sharpie. I did a console refresh with new leather boot and used the silver sharpie to redo my striping on the choke panel. Worked wonderfully. The pen is so easy to control and regulate how fast to go. Highly recommend it. I never even thought about doing the glove box.\
Note, I did notice that I installed my shift boot backwards! DOH! the stitching is facing forward instead of backwards...
now it all has to come off again!
Edited by Zedyone_kenobi
I have been using the silver sharpie trick for many years. I am lucky that my silver Z is a nearly perfect match for the sharpie. I can use it to quickly cover up pebble nicks in the paint.
I also used it to highlight the lettering on the valve cover, after painting the cover a contrasting satin black.
Edited by cygnusx1
  • Who's Online   2 Members, 0 Anonymous, 1,227 Guests (See full list)
