Is there anyway to check a fpr off the car? I was thinking about drawing a vacuum with a vacuum pump and checking to see if there is any leak down over a period of time. I would think that the fpr should hold the vacuum. If it didn't would that indicate a leaking fpr? Thanks
https://www.classiczcars.com/topic/32304-testing-fuel-pressure-regulator/
Just go buy an inline fuel pressure gauge, they don't cost much - and put it on the outlet side of the fpr. Most fpr's work by pushing a spring up to allow fuel flow.. I don't think pulling a vacuum on one would tell you anything useful..
