sliprenoodle Posted July 20, 2009 Share #1 Posted July 20, 2009 77 280z , put in a new fuel pump started right away. After a few days tried again nothing ,cranks put I cant hear the pump, a little later that day started. Any ideas? Troy Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/ Share on other sites More sharing options...
SteveJ Posted July 20, 2009 Share #2 Posted July 20, 2009 Yes, check the voltage at the pump when you don't think you can hear it. If it has voltage, you have junk in your trunk, er, tank. If that's the case, have the tank drained, boiled & sealed. Always have the tank full when you have the car sitting for more than a couple of days, too, to prevent condensation in the tank. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-289981 Share on other sites More sharing options...
sliprenoodle Posted July 20, 2009 Author Share #3 Posted July 20, 2009 Thanks I'll take a look today. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-289997 Share on other sites More sharing options...
sliprenoodle Posted July 23, 2009 Author Share #4 Posted July 23, 2009 The voltage was 9.6 does that sound about right? Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290180 Share on other sites More sharing options...
SteveJ Posted July 23, 2009 Share #5 Posted July 23, 2009 That sounds low to me, unless you Canadians are using Imperial volts. First, is your battery in good shape? Does the voltage drop a lot when you're cranking it? Next, look at a wiring diagram. I'm not a 280Z person, so I don't know for sure how the pump is wired, but I would expect it to get its voltage through a relay. If there is a relay, it could be suffering from soft contacts. If there isn't a relay, it could be suffering from 30+ years of corrosion. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290185 Share on other sites More sharing options...
Jeff G 78 Posted July 23, 2009 Share #6 Posted July 23, 2009 Like Steve said, you may have rust in the tank. If that's the case, the filter screen in the new pump would be clean to start with and then clog - not allowing it to start the next time. Pull the fuel inlet to the pump and remove the filter. If you see gunk, you have to drop and clean the tank. Been there, done that. If it's clean, look at the electrical system. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290191 Share on other sites More sharing options...
a7dz Posted July 23, 2009 Share #7 Posted July 23, 2009 Do the easy stuff first. The power at the pump should be the same as the battery.. Make sure you have power to the pump. If you have power does the pump run. I have seen several of these go bad in the last year. If it runs does it pump fuel? and at what pressure. Have you checked the fuel filter. Just because the pump is new/ rebuilt does not mean it works just that it is new. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290206 Share on other sites More sharing options...
sliprenoodle Posted August 1, 2009 Author Share #8 Posted August 1, 2009 Ok I'm sure its the tank, its dirty rust and stuff. were and how do I get it cleaned? Also I'm thinking I should relpace pump what do you recommend?Thanks for all the help guys. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290926 Share on other sites More sharing options...
Jeff G 78 Posted August 1, 2009 Share #9 Posted August 1, 2009 Start by removing the round inspection lid under the false floor in the hatch. It is to the right of the tire well near where the tools sit. Once you remove the cover, turn the lock ring, unplug the connector and remove the fuel sender. With the sender out, shine a flashlight down in the tank (not a trouble light!) and find out what the bottom looks like. If it's gunky or rusty, it's time to drop the tank and clean it out. Soak the fuel tank straps for a day or two in PB Blaster or other penetrant and remove the tank. The hoses can be tricky, but they will come off. Once the tank is down, order the POR-15 fuel tank kit online from the POR15 store and follow the directions EXACTLY! It takes several days to do right, but will fix your tank for good (only if done BY THE BOOK). Here was my tank before and after. It is a messy, no-fun job, but the results will be worth it. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290928 Share on other sites More sharing options...
sliprenoodle Posted August 1, 2009 Author Share #10 Posted August 1, 2009 Thanks jeff I'll take a look in the tank right now.I'll let u know what I see. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290929 Share on other sites More sharing options...
Jeff G 78 Posted August 2, 2009 Share #11 Posted August 2, 2009 BTW, getting photos of the inside of the tank to come out is really tough! You can either get the camera lens or light in the tank, but not both. Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-290930 Share on other sites More sharing options...
sliprenoodle Posted August 3, 2009 Author Share #12 Posted August 3, 2009 Tank is not to bad ,pump is gone. going to put in the g3 filter for now and get a new pump.What pump do u recommend Link to comment https://www.classiczcars.com/topic/32579-sometimes-yes-sometimes-no/#findComment-291000 Share on other sites More sharing options...
