I've been a casual car guy all my life. My nephew just inherited a 1973 240Z and called me to help him get it running. We've changed oil, filter, air filters, coolant, hoses, complete tune-up. It now fires up and idles, but we have two issues; 1. At first it was getting no gas to the carbs. We found out about the second, electric fuel pump by the gas tank and after temporarily bypassing it, the car started and idled fine. 2. The clutch is very soft and the transmission will not go into any gear. I could use some troubleshooting advise on the clutch and also on how to remove the filter from the electric fuel pump (since a late year addition, it's not mentioned in the shop manual).
Thanks,
Gary
https://www.classiczcars.com/topic/32736-new-in-vadc/
Assuming the elec fuel pump looks like the one in the attached pic, the bottom just twists off. Try hitting the joint with some penetrant to loosen things up and apply force with a strap wrench or a pair of channel locks if you don't care about the finish. You can also try tapping the base with a small hammer to break it free. I recommend removing the base while still mounted to the car and DO NOT recommend placing it in a vise.
https://www.classiczcars.com/topic/32736-new-in-vadc/#findComment-291167
Thanks for the tips and diagram guys. I am in Alexandria and my nephew (and the Z) are in DC. By the way, back in '71, I tried to test drive a Z, but they were so in demand in my hometown in Ohio that there were none in the showrooms. You had to put down a whopping $100 deposit (don't laugh, that was serious cash in '71) and give them four color choices. They'd call you when your name came up. They also arranged with a few previous purchasers to come in on weekends and paid them to give test drives to prospective customers. Never did get my Z. Maybe my nephew will let me drive his.
Gary
https://www.classiczcars.com/topic/32736-new-in-vadc/#findComment-291201
Thanks. The more we thought about it, the more we came to the same conclusion. and you're right - they're cheap. Napa had the slave in stock and the master available next day. Hope this does the trick. They've made room in the garage for the Z...all they need is a way to drive it in there before my nephew leaves for collage.
https://www.classiczcars.com/topic/32736-new-in-vadc/#findComment-291797
  • Who's Online   2 Members, 0 Anonymous, 663 Guests (See full list)
