Indicators/Flashers Don't work
Hi guys I'm in need of urgent help here only because I need to get my car road worthy to change it into my name.
The indicators or flashers don't flash properly they just stay stuck on either right or left no blinking. I believe it's the actual unit but any suggestions as to what I could look at or what it could be would be much appreciated.
https://www.classiczcars.com/topic/3275-indicatorsflashers-dont-work/
If activating the turn signal switch either direction lights the lamps, it would indicate to me that the switch is fine, but the relay may be to blame.
Have you checked/replaced the blinker relay? Consult your service manual for it's location and procedure for replacing.
