hey all So i ditched the weber DVG carbs on my early 260z
and picked up a set of 72 SU carbs in good shape and got all the to the fire wall!
But the joint/ socket does not match the with the 72 linkage do I have to find all that linkage at the firewall to make it all work?
I can post photos if needed!
https://www.classiczcars.com/topic/32795-carb-link-age-at-fire-wall-240260/
AH! I see the problem now!
seems 73 to 74 had a different shaft from the balance tube to the fire wall I have the 72 but need the shorter 73-74 that has a boot on it!
here is the old set up!
new hybrid parts
74 intake N36 with 72 balance tube E48?
Or the firewall bracket from the 240Z. They're almost the same on the 240Z's. The 260Z had the "Sliding Shaft" style that won't work on the 240Z linkage, which you already found out.
Ask around, you might find one here or there for cheap.
  • Who's Online   0 Members, 0 Anonymous, 1,083 Guests (See full list)
