Hi all,
I'm about to get my car started and I need damper oil for my carbs but NAPA, AutoZone, and Shucks all don't have it. I went to a local import auto shop and they told me that I could just use normal transmission oil. Is this correct? Or should I just order SU carb damper oil from the BD catalog?
Thanks,
John
https://www.classiczcars.com/topic/32810-su-carb-damper-oil-question/
3in1 Blue Label Motor Oil is a non detergent 20 Weight. I have been using it for years. Also any good hardware stocks 20 Weight non-detergent in quarts. Price about 3.00 for the 3 in 1 3oz container. Quarts of 20 non-detergent run about 3.00 also, but do not have the handy spout.
Alan
Thanks guys. I got the 20 wt fork oil. I went to every hardware store around here and no one had the 3in1 blue label! So then I went to tons of motorcycle shops looking for 20 wt but everyone had like 5 and 10 wt. Eventually I found it at a Honda dealer :)
Thanks everyone,
John
I use this 20 wt compressor oil that I got from Sears http://www.sears.com/shc/s/p_10153_12605_00916427000P?vName=Tools&cName=Air+Compressors+%26+Air+Tools&keyword=compressor+oil. The bottle is perfect for squirting the oil in without making a mess.
-Mike
Thanks everyone,
John
I found 3 in 1 oil in 20wt at Ace Hardware.
