  • 5 months later...
I just replaced the plastic washer under the spring and replaced what appeared to be atf with the all in one 20 wt. Even though everything is now cleaner than before the piston is much harder to compress. Before it didnt take anything to move them up and now it has a lot of resistance like it has a functioning shock absorber. Should it be that hard to move? I am quite sure everything is centered up and the needle isnt dragging.
  • 2 months later...
did you ever get the hard-to-compress issue fixed? Mine is that tough to move too. Its also like a shock absorber, no way in hell that venturi air movement is going to lift it. I'm waiting for my rebuild kit to arrive before I start wrecking gaskets.
