regularjoe Posted August 30, 2009 Share #1 Posted August 30, 2009 Ok, my 72' 240Z that used to race SCCA ITS is going back onto the road and I have to dump the welded rear end. I have a R180 that has a 4.3?? ratio out of the front of an 80 something pickup, does anyone have any experience with this ratio in a street/auto x car? I think I still would get plenty of highway speed while gaining quickness out of the tight corners. I have 4 other 180s and 1 200 I need to check yet if there is a particular ratio that comes recomended.Thanks in advance,Regular Joe Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/ Share on other sites More sharing options...
Arne Posted August 30, 2009 Share #2 Posted August 30, 2009 Joe, a 4.3 is dang low ratio for street use, especially with the shorter profile tires people often use these days, and very much so without a 5 speed. With a 4 speed you're going to be turning some pretty significant revs on the highway with that diff. Exactly how many depends on the tire size.A stock 240Z has an overall ratio in third gear of 4.77 (1.42 x 3.36). So 4th gear with a 4.3 is going to be in the same ballpark as 3rd in a car with stock gearing. Top speed of maybe 100 at redline.... Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293274 Share on other sites More sharing options...
regularjoe Posted August 30, 2009 Author Share #3 Posted August 30, 2009 Joe, a 4.3 is dang low ratio for street use, especially with the shorter profile tires people often use these days, and very much so without a 5 speed. With a 4 speed you're going to be turning some pretty significant revs on the highway with that diff. Exactly how many depends on the tire size.A stock 240Z has an overall ratio in third gear of 4.77 (1.42 x 3.36). So 4th gear with a 4.3 is going to be in the same ballpark as 3rd in a car with stock gearing. Top speed of maybe 100 at redline....I was guessing at 110 mph for the top speed at red line. But just guessing, is there a list of the gear ratios for the 4 and 5 speed trannys? I have those other rears to check out, I think one of them is a 3.92 or something like that. I also have a couple of trans and if I remember one is a 5 speed, maybe that would make the 4.3 workable.Thanks again,Regular Joe Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293282 Share on other sites More sharing options...
Mike B Posted August 30, 2009 Share #4 Posted August 30, 2009 I agree with Arne, 4.3 is probably too low for highway use, even with a 5 speed. I think most people prefer a 3.9 or 4.11 with a five speed. Here is a link to an online calculator that should be helpful http://www.geocities.com/z_design_studio/.-Mike Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293286 Share on other sites More sharing options...
26th-Z Posted August 30, 2009 Share #5 Posted August 30, 2009 The 3.9 final gear was standard for the F5C71A-5 five speed. We got the 3.364 final gear with the F4W71A-4. There are several final gear sizes in the competition catalogs however they are all listed as limited slip. This site may be of help http://www.geocities.com/z_design_studio/But generally I agree with Arne, a 4.3 is dang low for street use. Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293288 Share on other sites More sharing options...
Mike B Posted August 30, 2009 Share #6 Posted August 30, 2009 You type too slooowww Chris;).-Mike Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293289 Share on other sites More sharing options...
regularjoe Posted August 31, 2009 Author Share #7 Posted August 31, 2009 Thanks to all.Great info to get myself "edumicated".Joe Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293390 Share on other sites More sharing options...
rxsleeper Posted August 31, 2009 Share #8 Posted August 31, 2009 (edited) Hey Joe, I probably have a 3.54 open R180 that I would be interested in trading you for your 3.4?. Shoot me a pm if you are interested. I currently am running a 3.9 or 3.7 for the local tracks I hit. A 4.3 I could use on the hillclimbs. BTW, I keep a locked 3.54, 3.7, and 3.9 on hand. I have been promised a 4.11 from another racer I just need to pick it up. If I ever get enough coins I will upgrade to a Quaife. And to answer your question, With the 3.9 I see 7k rpm on the front straight at Nashville Speedway. It is too tall in my opinion for street use with the 4 or 5 speed. I would think a 3.7 or 3.9 coupled with a 5 speed would be a nice street combo. Enough grunt at the bottom and not too bad on RPMS in the uper gears. Edited August 31, 2009 by rxsleeper Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293394 Share on other sites More sharing options...
Mike B Posted August 31, 2009 Share #9 Posted August 31, 2009 With the 3.9 I see 7k rpm on the front straight at Nashville Speedway. It is too tall in my opinion for street use with the 4 or 5 speed. I would think a 3.7 or 3.9 coupled with a 5 speed would be a nice street combo. Enough grunt at the bottom and not too bad on RPMS in the uper gears.What speed are you going at 7k RPM with a 3.9 diff? I assume that is with a 5 speed? Using the calculator I linked to with an 81-83 factory 5 speed, an 81-83 280zx 3.9 R200 diff, and 205/60/15 tires, it calculates 3165 rpm at 80 mph in 5th gear. With that setup, 7000 RPM would be about 177 MPH.-Mike Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293403 Share on other sites More sharing options...
rxsleeper Posted August 31, 2009 Share #10 Posted August 31, 2009 FWIW, I am using the OEM 4 speed per the class rules (ITS) and 225x50x14 Hoosier R-6's. I think it works out to about 122 mph. A couple of the other guys are running a 4.11, same tranny, and 225x50x15 IIRC and they pull me on the straight. I know this year the 2nd place car changed tire diameter to drop his rpms on the straight. I just don't remember exactly what size he went to. He was seeing 7100-7300 on the front straight. Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293405 Share on other sites More sharing options...
Galaxybj Posted September 1, 2009 Share #11 Posted September 1, 2009 JFWIW - In 1972 I put the comp 5 speed in hls30-30855 using the gearing that the 2000 roadster had and the comp 4.44 lsd. Overall ratio in 5th was 3.77. I never felt that it was too low geared for the highway and got decent mileage too. I had engine work (cam, distributor, SM needles) done at FAR Performance so it was putting out more hp over stock, but not a lot more. I never minded the bit higher rpm's and enjoyed the performance. I look forward to getting her back on the road - maybe next year. Link to comment https://www.classiczcars.com/topic/33003-final-drive-ratio/#findComment-293447 Share on other sites More sharing options...
