Oiluj Posted September 1, 2009 Share #1 Posted September 1, 2009 OK, I serarched previous treads but am still not clear… Will a larger bore 280ZX brake master cylinder bolt-up to a 1973 vacuum master vac unit without modification? Do I need to re-route brake lines?Thanks! Link to comment https://www.classiczcars.com/topic/33021-280zx-master-cylinder/ Share on other sites More sharing options...
Zs-ondabrain Posted September 1, 2009 Share #2 Posted September 1, 2009 Start reading............http://forums.hybridz.org/showthread.php?t=104735 Link to comment https://www.classiczcars.com/topic/33021-280zx-master-cylinder/#findComment-293488 Share on other sites More sharing options...
Oiluj Posted September 1, 2009 Author Share #3 Posted September 1, 2009 Start reading............http://forums.hybridz.org/showthread.php?t=104735Thanks! It's a great read...Also, the last section on aligning the pad pins with the caliper piston may solve the problem I'm having with setting-up my brakes! Link to comment https://www.classiczcars.com/topic/33021-280zx-master-cylinder/#findComment-293495 Share on other sites More sharing options...
