Frankensteinz2 Posted September 14, 2009 Share #1 Posted September 14, 2009 Hey guys, I just need some direction. I can turn my blinkers on, and they work fine, with no headlights. However with headlights on, my tach shows a weak, but solid, passenger side blinker on the tach, no affect on the outside of the car, just on the tach. Is this a device put in for a bulb out, or is this likely the combo switch?ThanksFrankie Link to comment https://www.classiczcars.com/topic/33182-blinkers-headlights/ Share on other sites More sharing options...
EScanlon Posted September 14, 2009 Share #2 Posted September 14, 2009 If the problem is the same with your Parking Lights on (no headlamps), then you may have a cross-connected bulb.If on the other hand, it's ONLY when the Headlamps are on, then I would suspect the combination switch.HTHE Link to comment https://www.classiczcars.com/topic/33182-blinkers-headlights/#findComment-294706 Share on other sites More sharing options...
Frankensteinz2 Posted September 14, 2009 Author Share #3 Posted September 14, 2009 Ok thanks again Escanlon.Frankie Link to comment https://www.classiczcars.com/topic/33182-blinkers-headlights/#findComment-294707 Share on other sites More sharing options...
Zs-ondabrain Posted September 14, 2009 Share #4 Posted September 14, 2009 Sounds like a weak electrical system. Watch your Ammeter/volts meter as well. You may see it doing something similar. The headlights use more power than almost anything else in the car, so with all that power draw, the tach is showing the jump in usage from the Turn signal. I might suggest a Headlight Upgrade Harness or upgrade to the 81' to 83' 280ZX alternator and ZXP adaptor.Dave Link to comment https://www.classiczcars.com/topic/33182-blinkers-headlights/#findComment-294718 Share on other sites More sharing options...
