Oiluj Posted September 20, 2009 Share #1 Posted September 20, 2009 Looks like my rear proportioning / residual pressure valve is the culprit.Looked in the classifieds, but no joy.I can put in a after-market valve, but would prefer to use the correct one. Anybody have one they are willing to part with? Link to comment https://www.classiczcars.com/topic/33260-anybody-have-a-spare-rear-brake-valve/ Share on other sites More sharing options...
Maples71240Z Posted September 20, 2009 Share #2 Posted September 20, 2009 Looks like my rear proportioning / residual pressure valve is the culprit.Looked in the classifieds, but no joy.I can put in a after-market valve, but would prefer to use the correct one. Anybody have one they are willing to part with?If the valve is just plugged up it can be taken apart and cleaned up. Any aftermarket valve will need adapters and will end up not fitting correctly where the old one was. Link to comment https://www.classiczcars.com/topic/33260-anybody-have-a-spare-rear-brake-valve/#findComment-295249 Share on other sites More sharing options...
Oiluj Posted September 20, 2009 Author Share #3 Posted September 20, 2009 It doesn't seem clooged, it's just not working.Problem is I can't get it apart to check it.. The outer seal is easy. The inner piston & seal won't come out. Link to comment https://www.classiczcars.com/topic/33260-anybody-have-a-spare-rear-brake-valve/#findComment-295260 Share on other sites More sharing options...
TomoHawk Posted September 21, 2009 Share #4 Posted September 21, 2009 There is a place called Rod's Datsun parts (http://www.rodsdatsun.com) in San Jose. He would probably have what you need. Get some Datsun T-shirts too.thxZ Link to comment https://www.classiczcars.com/topic/33260-anybody-have-a-spare-rear-brake-valve/#findComment-295273 Share on other sites More sharing options...
Maples71240Z Posted September 21, 2009 Share #5 Posted September 21, 2009 It doesn't seem clooged, it's just not working.Problem is I can't get it apart to check it.. The outer seal is easy. The inner piston & seal won't come out.Is this valve on the firewall? What year is your Z? Link to comment https://www.classiczcars.com/topic/33260-anybody-have-a-spare-rear-brake-valve/#findComment-295290 Share on other sites More sharing options...
Oiluj Posted September 21, 2009 Author Share #6 Posted September 21, 2009 It's a 1972. The valve is just above the rear suspension under the car on the passenger side. It is the brass valve just before where the rear brake line T to the rear wheels. Link to comment https://www.classiczcars.com/topic/33260-anybody-have-a-spare-rear-brake-valve/#findComment-295293 Share on other sites More sharing options...
