jgkurz Posted October 5, 2009 Share #1 Posted October 5, 2009 Hi All,I'm reaching out to the masses for help with an perplexing problem on my 77 280Z with Modern Motorsports 240sx rear disk and 280ZX CV conversion kits. Here's the issue. Recently my left rear wheel is making a clicking when I take off from a stop. This happens intermittently and does not matter whether I'm going forward or in reverse. I only hear the clicking on the initial movement of the car. Nothing is heard after I get rolling. I have checked the CV shaft bolts, lug nuts, wheel bearing play and break shoe clips but everything is perfect. The clicking SEEMS like it is near the wheel and not in the differential area. It occurs whether it's warm or cold. I don't think it's a wheel bearing since the noise is not the typical growl and seems more external. Can a bad wheel bearing make a clicking noise?? Applying the brakes or ebrake does not affect the noise in any way. It almost sounds like an outer CV shaft joint but I hate take it out unless I'm sure.Any thoughts?Thank you,John Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/ Share on other sites More sharing options...
draztik280 Posted October 5, 2009 Share #2 Posted October 5, 2009 I do have this problem too. But cannot determine how to fix it. It's annoying. I will be replacing all the rubber bushings and replace it with the polyurethane kits underneath and see if this will go away.. Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/#findComment-296497 Share on other sites More sharing options...
EScanlon Posted October 5, 2009 Share #3 Posted October 5, 2009 Have you checked for a rock or a screw or some other object in the tire tread? That may seem too obvious, but you'd be surprised how often you DO hear it at low speeds, only to NOT hear it at higher speeds.Worth a check.E Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/#findComment-296499 Share on other sites More sharing options...
jgkurz Posted October 5, 2009 Author Share #4 Posted October 5, 2009 Have you checked for a rock or a screw or some other object in the tire tread? That may seem too obvious, but you'd be surprised how often you DO hear it at low speeds, only to NOT hear it at higher speeds. Worth a check. E The tread is clean. I wish it was that easy..... Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/#findComment-296500 Share on other sites More sharing options...
theramz Posted October 5, 2009 Share #5 Posted October 5, 2009 If your car is lowered it could be a bind caused by the slightly longer axles.Or your hub has loosened up on the stub axle. Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/#findComment-296502 Share on other sites More sharing options...
jgkurz Posted October 6, 2009 Author Share #6 Posted October 6, 2009 If your car is lowered it could be a bind caused by the slightly longer axles.Or your hub has loosened up on the stub axle.A loose stub axle nut might be the cause. I think I'm going to take in the CV shaft in to be checked then verify the the nut is tight. Thanks for the idea. Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/#findComment-296546 Share on other sites More sharing options...
dimitri_zee Posted October 6, 2009 Share #7 Posted October 6, 2009 I used to get that exact sound till I found it was a half shaft uni joint. But you stated you have a CV conversion so that eliminates that! Check your tailshaft uni joints. Noises seem to "travel" around from under the car.. Link to comment https://www.classiczcars.com/topic/33424-strange-clicking-in-rear-wheel-area/#findComment-296556 Share on other sites More sharing options...
