I am still working on my Z little by little. At the body shop today I was asking the guy about my hood latch, which often pops up (thank goodness Z cars have hoods which open the right way!)
He instantly noticed something I had missed all this time: the hood is hitting on the top of my radiator! And it's wearing through the brass at a good clip.
Now, this is a car that (now that I have owned it for a while) shows every sign of having been made from parts of about 3 other cars (one of them a Maxima!).
So my questions are:
1) Is this the right radiator for my '78 280z? If not and I just get a new radiator, will the problem be magically fixed?
2) If it IS the right radiator, what is the least-painful way to fix this problem? Are any of Motorsport's radiators shorter? Should I drill some new holes in the mounts or fabricate new mounts to shift it down?
The dimensions of the radiator seem to be about:
2 5/8 inches deep (thick)
20 3/4 inches tall
24 1/2 inches wide
Thanks for any advice!
https://www.classiczcars.com/topic/33544-hood-hitting-radiator/
20 3/4 inches tall
24 1/2 inches wide
I do not believe this is the right radiator for the car. And installing MSA shrould will not help the situation at all. Raight radiator should cure the problem.
Esprist
www.jdm-car-part.com
mgood's radiator looks exactly like the one on my 78 (except for the lack of a shroud). The one you have there sits too high above the support. You cold try drilling holes in the bracket that would allow it to mount lower provided that wouldn't create a clearance problem at the bottom.
20 3/4 inches tall
24 1/2 inches wide
Just lower the radiator a inch. All you need to do is elongate the mounting holes or drill new ones and set the radiator lower. I mounted a 280Z unit in my 240 and it is 2'' longer. I just set it low enough to clear the hood and all is well.
Gary
  • Who's Online   0 Members, 1 Anonymous, 1,340 Guests (See full list)
