g9m3c Posted October 26, 2009 Share #13 Posted October 26, 2009 I forgot to add the bit about buying new bolts. The other guys have me covered here though. Definitely get the new bolt kit from MSA. It costs, what, 5 bucks? Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-298584 Share on other sites More sharing options...
Pomorza Posted October 26, 2009 Author Share #14 Posted October 26, 2009 Do have a question for you all. I ordered the pump and bolts and its on its way. Upon installation is an RTV required on the pump. I haven't yet looked at the FSM or other books about the car but I'm wondering what you guys have done. From what it looks like my pump has a crap ton of red RTV holding it on the block. Not sure if there is even a gasket there. Advise is appreciated. Jan Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-298618 Share on other sites More sharing options...
g9m3c Posted October 26, 2009 Share #15 Posted October 26, 2009 Yea, there is a gasket. I used a thin layer of RTV on both sides of mine and no leaks so far. Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-298625 Share on other sites More sharing options...
motorman7 Posted October 26, 2009 Share #16 Posted October 26, 2009 I personally prefer a thin film of silicon on the gasket, both sides. Too much and I dont think you get even pressure on the gasket when torquing. No RTV and the inconsistencies of the metal (warp, pits) may lead to small leaks. Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-298627 Share on other sites More sharing options...
ZCurves Posted November 3, 2009 Share #17 Posted November 3, 2009 I had to chime in...I have pretty much done all of that with my Z over the last 25 years. One thing everyone should check/change when doing a water pump replacement are the little Belt Tensioner Bearings. They are around $10 ea and will quiet your engine alot! They are the source of many 'mystery' noises. Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-299337 Share on other sites More sharing options...
sblake01 Posted November 3, 2009 Share #18 Posted November 3, 2009 If you're talking about idler pulley bearings, you'd only need to check/change them if your car had them. Those would only be on the ones that have AC. Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-299338 Share on other sites More sharing options...
Pomorza Posted November 3, 2009 Author Share #19 Posted November 3, 2009 sblake01 I took my A/C belt off months ago as I don't use it at all. It was most definitely the water pump as I took it off and found the bearing burned. (I disassembled the pump...had some free time). There was also a stream of coolant coming from the weep hole on the old pump. Had a nice adventure putting the new one in. Jan Link to comment https://www.classiczcars.com/topic/33647-now-what-can-go-wrong/?page=2#findComment-299344 Share on other sites More sharing options...
