Well, I got my plating kit early. Actually, got the Caswell hardware and manual on e-bay for $43 total (includes shipping). Such a deal, I couldn't pass it up. It's used, but everything seems to be in working order. I ordered the chemicals on-line and should have everything by early next week. The cost of the chemicals is actually fairly cheap. The shipping costs are more than the actual materials cost. The most expesnsive item was the yellow chromate from Caswell. Not sure if I can get this cheaper somewhere else, but will check into it.
I cleaned up the garage a bit and set aside an area for the plating buckets. I also made a rotating 'bucket' for plating quantities of nuts and bolts. I hope to try my hand at plating as soon as the chemicals come in. Perhaps by the end of next week. I will post pics of the progress.
Also, here are a couple sites that are pretty helpful with plating info.
http://www.thisoldtractor.com/gtbender/zinc.htm
http://www.nulltime.com/zincplating/index.html
Rich
After using the kit a little, I took some time to GOOP a stick to the side of the big jug (which contans the eletrolyte) so I can attach an arm. That way I can clamp the part's wire to it and walk away (or just rest my arm) even though the plating process only takes a few minutes or less.
In the meantime, you can get yourself a few lengths of different gauges of copper wire. Remember to get ever last bitof rust off, and grindd/sand/polish the surface to perfgection before plating (if possible.)
I will get a few pics of my plated water fittings & hose clamps soon.
thxZ
Edited by TomoHawk
I have used Eastwood's tin/zinc plating kit with good results. As previously mentioned, surface prep of the part to be plated is key. I start by cleaning the parts to be plated in hot, soapy water to remove all grease & dirt. Really dirty parts may require wire brushing and cleaning with brake cleaner. I then use a produce called Evaporust to remove any surface rust on the part. I've found that a small, brass bristle brush will help shine up the parts after they have been plated.
Did you notice the plating site on nulltime.com is a 240Z guy!
http://www.nulltime.com/zincplating/parts/datsun_240-z_parts.html
Is he on classicZcars? Whois says its Sean Collins from Idaho. Sean, if your listening, thanks for taking all the time to document the setup!! :beer:
  • 1 month later...
I got my Caswell plating kit set-up and plated some parts today. It took a bit of practice, but I am very happy with the results. The difficult part was getting the right current to produce the bright color.
I originally tried doing the plating the cheap way by just getting the chemicals (NaOH and ZnO) off of e-bay, but the plating came out dull. So, I had to pop for the Caswell kit in order to get the parts to have the correct shine. Below are 2 pics of the dull finish and 2 of the Caswell kit finish. Also have my plating shelf shown here.
I am actually pretty thrilled about being able to do this myself. When I strip the 71Z at the end of February here, I want to re-zinc all of the bolts that I take off while the body is off to paint. Should make it look nice when it's all put back together.
I bought the 3-gallon kit ($205) and the yellow chromate liquid ($30). Add shipping and it's a little over $250. Also got a crock pot (for heating the solvent) from target and Muriatic acid and a couple of buckets from Home Depot. So the whole package is roughly $300.
They tell you how to dispose of it in the enclosed Caswell plating manual. Essentually you neutralize it with a base..baking soda, then dispose.
Also, I am getting much better with this. It's actually pretty exciting. Here are some more samples. Got my son doing it now for parts on his T-bird.
They do look very nice.. How long do they soak?
Is this the kit: http://www.caswellplating.com/kits/zinc.htm
John
Roughly 15 mins in the 'pickle' and 15 mins in the plate tank, 30 seconds in the chromate.
Yes, that's the kit I have. Works well after a little practice.
Rich
  • Who's Online   2 Members, 0 Anonymous, 499 Guests (See full list)
