Marty,
spindle pins arrived today, thank you so much. I still need to get to the Post Office (if I can ever get out of my office before they close) to get the pads to you. Bear with me, I havent forgotten!!
All others, I would love to see this thread that Marty started continue. Its a great idea and would be beneficial to alot of members Im sure.
Bearing that in mind, if anyone has a spare 5 speed in good condition lying around, let me know :)!!!
Edited by MEZZZ
Thanks, Ron! :)
On that note, I think the only spare Z parts I have (that I'm not keeping) are a set of used carbon-core plug wires in decent condition. Admittedly sort of slim pickings in the Z department.
That said, I have a few nice '65/'66 Mustang parts taking up room in my garage. Any Mustang owners here? If so, PM me, and I'll see what I might have for you.
I think I also have some new brake pads (front?) for a '90 Volvo 240 that I no longer own.
Peace,
Sarah
Edited by FastWoman
Bump, for some nice parts still left. Pictures in the first post.
- Pair door handles. Few pits and scratches, but work well.
- '70-71 Shifter to tunnel grommet. New!!
- Stock coils. They would work fine on a driver.
- '83 fan and fan clutch. clutch feels good.
- '83 thermastat housing
- '83 Pulley
- '70 Water Pump pulley cover. Great core to send in for re-plating.
- '70-71 Fan clutch. Not pretty but worked well when removed.
- Left side headlight cover. Good condition, with gasket.
- Energy Suspension bump stops. - New!!
- '70 - 71 Tool covers. A couple of cracks, but very serviceable for a driver that has them missing.
Let's get in the spirit and keeps this going!!
Marty
Shifter grommet, tool covers and bump stops have been gifted to a new home.
Marty
I'll offer up a fixing plate and mount from a S130 distributor. If I recall correctly, these are the bits needed (and often overlooked) for the upgrade from points to electric distribution (someone please correct me if I'm wrong)
However, I seem to have misplaced the bolts that go with it...
(edit: spoken for as of 6 pm est)
I do have another set, but don't have the rubber gasket for it.
Edited by zbane
Dustin, Bob and H.H., your parts are on there way. With a little luck, you might have them before Xmas.
There are a few parts left:
- '83 Pulley
Marty
Marty,
Ashtray recv'd, repaired (decent job if i do say so myself) and now has home in my console. VERY much appreciated.
and now to keep paying it forward..........
1 set (used) visors in red. good shape, no tears, slight silver overspray looks like it can be cleaned off or left.------TENTATIVE
1 set poly bumpstops (new) in blue------------- GIFTED
1 set poly bushings (new) in black for rear struts------------- GIFTED
1 pass rear wheel cylinder (new) for 240z with brake hard line straight out from cylinder. My '71 had the angled brakeline and I had this one too long before i went to install to return.------------- GIFTED
1 set (used) quarter window louvers. Black plastic (ABS?) driver's side has 1 crack looks to be repairable, pass side no cracks. Slightly faded, i'd recommend a quick spray.------TENTATIVE
Edited by mlc240z
I have a set of rear louvers pulled off my 280z. They seem to be aluminum, not plastic, and are currently painted orange. It's big so I expect boxing and shipping will probably be in the $30 range, assuming I can find an appropriate sized box. Yours for the asking, as I'm not a big fan of louvers..
Geof
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
