I just purchased a 1978 280Z had it shipped from CA to Wisconsin "Completly Rust free". I plan on restoring this over the winter, my question is the Dash. My dash has a small crack and I have read several links regarding replacement which can be very costly so I was looking at options of repairing or a dash cap. I have been looking at 1000's of sites and was wondering who has the best dash cap. It seems that even if you do repair a dash it will probably end up cracking again. I also noticed that you can get a full dash cap or just the upper cap. I would appreciate any suggestions. Thanks
https://www.classiczcars.com/topic/34191-dash-caps/
Not sure about the 280's but on my 260 once I installed the full dash cap, the difficulty associated with removing some of the gauges increased 100 fold. Something to consider.
In retrospect,
Dash cracked=small problem... $90 problem solved
however,
Full dashcap and broken gauge = Big problem, starting with the phrase "you have to be kidding" followed by an immediately diminished appreciation of your full dashcap
https://www.classiczcars.com/topic/34191-dash-caps/#findComment-303828
