Kris.is.awesome Posted December 20, 2009 Share #1 Posted December 20, 2009 Allright, so I was digging through my bags of parts I got with my car- and I came across this. I believe it's a replacement VR- maybe you guys can help. It has the same plug, and bolts right up where the other one does. So whatcha think? Is there a way to test it? Original on left- new part on right. Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/ Share on other sites More sharing options...
zKars Posted December 20, 2009 Share #2 Posted December 20, 2009 If it smells like a duck and quacks like a duck, its a VR for sure.... Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303808 Share on other sites More sharing options...
Kris.is.awesome Posted December 20, 2009 Author Share #3 Posted December 20, 2009 If it smells like a duck and quacks like a duck, its a VR for sure....Better to be safe than sorry!Thanks! Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303810 Share on other sites More sharing options...
MikeW Posted December 20, 2009 Share #4 Posted December 20, 2009 When I saw the title of this post I thought for sure it was spam advertising a way to get a fake driver's license or something over the net. Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303818 Share on other sites More sharing options...
oldhemi Posted December 20, 2009 Share #5 Posted December 20, 2009 I have that exact VR on the right. I remember putting it on back in 75 or 76. Its about the only engine compartment item that is still shiny! Picked it up in a parts store. Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303822 Share on other sites More sharing options...
FastWoman Posted December 21, 2009 Share #6 Posted December 21, 2009 Yeah, that's what the VR from my '75 looked like (on the right). Your original part must be a solid state unit. It sort of looks like the difference between the old electromechanical VR in my Mustang and the solid state unit that replaced it.Is the electrical connector the same? Same color codes in each connector position? Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303825 Share on other sites More sharing options...
Kris.is.awesome Posted December 21, 2009 Author Share #7 Posted December 21, 2009 Yeah, that's what the VR from my '75 looked like (on the right). Your original part must be a solid state unit. It sort of looks like the difference between the old electromechanical VR in my Mustang and the solid state unit that replaced it.Is the electrical connector the same? Same color codes in each connector position?Pretty much, I think there may be a stripe or two difference, but almost down to the dot. Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303833 Share on other sites More sharing options...
FastWoman Posted December 21, 2009 Share #8 Posted December 21, 2009 I'd say you can plug it in and try it. Your alternator should put out about 14.5V, give or take. If it does, then the VR is doing its job.The electromechanical VR is the correct type, BTW, at least from a restorative point of view. The solid state VR is probably the better unit from a standpoint of functionality. Personally, I'd pretty-up the solid state one and use it, stashing away the electromechanical one for later use. Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303852 Share on other sites More sharing options...
Kris.is.awesome Posted December 21, 2009 Author Share #9 Posted December 21, 2009 I'd say you can plug it in and try it. Your alternator should put out about 14.5V, give or take. If it does, then the VR is doing its job.The electromechanical VR is the correct type, BTW, at least from a restorative point of view. The solid state VR is probably the better unit from a standpoint of functionality. Personally, I'd pretty-up the solid state one and use it, stashing away the electromechanical one for later use. I was thinking the same- but one of the wires coming out of it is badly frayed- and needs to be re-connected. I may try some surgery Link to comment https://www.classiczcars.com/topic/34193-super-quick-photo-id/#findComment-303890 Share on other sites More sharing options...
