How would you build a DSP AUTO-X Z
The drawback is the ball joint stud taper. You need to have the early arms machined to match the taper of the later ball joints. That's a gray area and might lead to a protest, if anyone is smart enough to figure it out. A defense might be that the original ball joints are NLA and this is part of a normal maintenance/repair process.
Vic's "full interior" was an interesting interpretation. It clearly was determined to be legal as it would certainly have been protested at Nationals when he won with it. It was, as I recall lightweight carpet screwed to the door panels and the same on the floor. It wasn't so much THE full interior as it was A full interior.
Very fast car and driver...
Anyone protesting that would have to know Z cars and your car like a brother. Not likely to be noticed.
The "C" is the cam from the 260Z if I'm correct. Again, this swap is a gray area thing - actually, its plain illegal given the update/backdate requires the engine to be swapped as a complete unit. But, based on how SCCA tests cams, the specs will be within their range of error when they measure duration.
Its not that critical of a change because the power difference is very small.
I sent an e-mail in requesting the change, although I'm not going to build a car for the class. I was much more interested in the short lived proposal to put the 280ZXT on the same line in BSP as the 240Z.
  • Who's Online   0 Members, 0 Anonymous, 1,038 Guests (See full list)
