Hi im having problem with my fuel pump.
im looking for replacement fuel pump.
anyone can recommend me any website to buy from?
i saw this in ebay.
http://cgi.ebay.ca/NISMO-Electric-Fuel-Pump-DATSUN-510-1200-240Z-110-120Y_W0QQitemZ370307534453QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item56380c8e75#ht_1708wt_939
https://www.classiczcars.com/topic/34344-240z-electric-fuel-pump/
What is the problem with the electric pump? Did you replace the filter that is inside the pump?
Is it the stock pump for a '73 or did someone replace the mechanical pump with electric?
Or perhaps you need a fuel pressure regulator to control the pressure going to the carbs.
Edited by Darrel
Facet sells an all but identical pump to the one from NISMO - shop the Web for the best price.
Facet Part FEP60SV - you can buy replacement filters FEP 42370.
Should be around $85.00... I've used them for years...
FWIW,
Carl B.
Carl, I have a FEP60SV Facet in the back of my '73 running as a feed for the mechanical. When you run the Facet pump as the only pump, do you close / clamp off the return line? I'd like to eliminate the mechanical pump but was hesitant to block the return line
By the way, the Facet is a very quiet pump, just a faint thunk noise from the back while it's pumping. The first one I had was burned up when my voltage regulator failed but it was an unbranded Facet. It was labeled a Purolator, and was much cheaper than the Facet branded pump. Both were Made in USA surprisingly enough. I believe Facet is owned by Purolator now. My friend's tell me Facet's were the pumps to have back in the day when they were running their 510's and 18RG Celica's.
:beer:
  • Who's Online   0 Members, 0 Anonymous, 1,268 Guests (See full list)
