GreenZZZ Posted January 11, 2010 Share #1 Posted January 11, 2010 Got my front and rear control arm bushings installed (stock). Decided on stock mustache bar bushings. They are longer than I expected, but I figure after you press them in you have to flare the end somehow. Check the photo. Is this the right part ('72Z with an R200 swap). If its right, how do you press them in? http://www.classiczcars.com/photopost/showphoto.php?photo=32789 Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/ Share on other sites More sharing options...
Darrel Posted January 11, 2010 Share #2 Posted January 11, 2010 press in like normal, then the extra material will need to be hammered down on top of the mustache bar like the old one was.You will have to cut the old one out. Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-305766 Share on other sites More sharing options...
ZCurves Posted January 11, 2010 Share #3 Posted January 11, 2010 (edited) I used an grinder to take off the lip of the original bushing and then caved it in and drove it out with a chisel. Once you then driven the new one back in its place, you'll want to flare the lip back like the old one. You can hammer it into a lip or use a hacksaw and cut the bushing down to the Mustache Bar at the 12, 3, 6 and 9 o'clock positions. Spray with some paint, done. Edited January 11, 2010 by ZCurves Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-305777 Share on other sites More sharing options...
GreenZZZ Posted April 28, 2010 Author Share #4 Posted April 28, 2010 (edited) This is what I ended up with... The bushing has different resistance to motion depending on the voids. I ended up randomly putting them in but with the stiffer resistance left/right and the weaker resistance front back which is opposite from the original (obliterated) bushings. I imagine anything is better than what was there which was almost no resistance... http://www.classiczcars.com/photopost/showphoto.php?photo=33404 Edited April 28, 2010 by GreenZZZ type-o Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-317560 Share on other sites More sharing options...
esmit208 Posted April 28, 2010 Share #5 Posted April 28, 2010 I apologize for not responding before noe GREEN. I used an acetlyne torch and just waited for them to disintergrate....only took a few moments and the mustache bar did not disfigure. To re-install I used a standard shop press and had no issues. Mine don't quite look like your though. I would probably re-install those if I were you. Most repair shops have presses if not a machine shop will. Good Luck Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-317568 Share on other sites More sharing options...
steve91tt Posted April 28, 2010 Share #6 Posted April 28, 2010 I did not know the stock mustache bar bushings were still available. Did you get these from Nissan? Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-317569 Share on other sites More sharing options...
GreenZZZ Posted April 28, 2010 Author Share #7 Posted April 28, 2010 Mine don't quite look like your though. I would probably re-install those if I were you. The bushings went in with a press, but I couldn't find anyone with the tool to flare the last 3/8" once pressed, so I followed ZCurves advice and slotted/whacked the collar to flare the end down. Then I sanded it with a dremmel. Paint is next.I did not know the stock mustache bar bushings were still available. Did you get these from Nissan?Nissan part bought from Motorsport (MSA/ZCarParts). There is another thread about gear whine/noise from using urethane bushings so I decided to go stock. Unlike the control arm bushings, the collar needs to be flared which is what I wanted to figure out here. The urethane bushings are real easy to install! Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-317571 Share on other sites More sharing options...
GreenZZZ Posted November 13, 2011 Author Share #8 Posted November 13, 2011 Ended up redoing the bushings as Kevin LeBlanc at the Austin Z-Clinic had a tool made up to do the flare. Worked great! Mustache Bar bushing flare tool Tool top, socket on the bottom Looks good! Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-371693 Share on other sites More sharing options...
madkaw Posted November 13, 2011 Share #9 Posted November 13, 2011 Do you think Kevin would lend,borrow, sell, that tool???It would save a lot of time and hassle for me to just use his tool to get the job done. If there is any way you can help make this happen I would appreciate it. Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-371705 Share on other sites More sharing options...
Mike W Posted November 13, 2011 Share #10 Posted November 13, 2011 Steve,I also had one of these made (in fact I think I had it done before Kevin). I have lent it out to one other member and am willing to do the same for you if it would help you out.All I request is that you take care of postage / mailing costs and return it back to me as soon as you are done so it is available for other members when they need it.Let me know.Mike. Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-371707 Share on other sites More sharing options...
madkaw Posted November 13, 2011 Share #11 Posted November 13, 2011 Mike,so your installer is the same? If it is just let me know your paypal and I will send you money so you can ship it to me!!I had just sent off a e-mail to Kevin, to ask to borrow his tool, but be glad to send you postage money and I will definitely send it back when I'm done. Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-371709 Share on other sites More sharing options...
Mike W Posted November 14, 2011 Share #12 Posted November 14, 2011 Steve,No Kevin did not do mine, although I do know him. I have had him do some work for me and he does great work, but unfortunately I did not know about Kevin and his shop when I was going through this. Through a long chain of events I got connected with a little shop in Austin called Scotty's Driveshaft and they made the tool for me. Not sure who made Kevin's for him.In any case I will send you a PM and give you my contact detials so I can get this to you.Mike. Link to comment https://www.classiczcars.com/topic/34369-stock-mustache-bar-bushing-flare/#findComment-371733 Share on other sites More sharing options...
