Can't spend money on a new ignition. How about a used MSD 6AL for $100? Or you could pay $135 for a Pertronix digital rev limiter that doesn't help with the spark. If you don't already have the ZX distributor I'll sell you my 6AL AND a ZX distributor that has the vacuum advance locked out for $150.
https://www.classiczcars.com/topic/34401-rev-limiter/#findComment-306014
I second that completely as I have been running an MSD 6L and a Pertonix in my Z for 9 yrs now with no issues at all.
The cheapest rev limiter I can think of is to set the throttle/gas pedal to limit the amount it will travel. Works but not what you're looking for.
https://www.classiczcars.com/topic/34401-rev-limiter/#findComment-306034
Yeah, me too. I took mine off and went to the track and was passing a friend coming onto the front straight, looked down and was up close to 8000 rpm, soon after the harmonic balancer went out and took out the front of the crank. It won't help if you find the wrong gear on a downshift, but it can prevent you from "getting excited" and not upshifting.
https://www.classiczcars.com/topic/34401-rev-limiter/#findComment-306078
Wish I could that would put me over my Crapcan budget....
Does the Pertronix work OK, I have found a used one cheap?
Thanks,
https://www.classiczcars.com/topic/34401-rev-limiter/#findComment-306159
