The thurmostat housing has a coolant hose connection comming out of it and from my research it seems that was orignaly connected to the intake manafold? Sence i'm running a tripple weber carb's and a cannon intake manafold what should I do with that coolant outlet on the thurmostat housing?
Thanks,
Colby
https://www.classiczcars.com/topic/34433-weber-cannon-thurmostat-housing/
I have a 73 so the threads on my fitting are 1/2 NPT (1/2" pipe). I used teflon tape and a pipe plug so solve my problem. I believe earlier models use British pipe threads but I am not sure of the exact size. I believe there is some discussion of this in the Ztherapy Excitement thread a couple posts down from this
  • Who's Online   2 Members, 0 Anonymous, 1,371 Guests (See full list)
