Hello All,
I've been going through boxes of parts and organizing so that it is easier to find things when i get to the point of reassembling my Z. This also includes making a list of parts that are needed. I pulled the radiator cap that was removed when the radiator went to be recored. Most of the bottom part where it seals is rotten away so I will need to replace it. I can not find an exact copy only the standard aftermarket replacement.
Does anybody know if the attached pic is original and if so if they are available somewhere or what the accepted alternative is in a restoration. I dont mind using the newer style if that is all that is available but if the old style is out there it would look better.
Thank You for any help, Jeff
https://www.classiczcars.com/topic/34436-original-style-radiator-cap/
Hello All,
I would just buy ones for 280Z and put this decal on;)
http://jdm-car-parts.com/item-for-sale/radiator-cap-decal-for-datsun-240z-260z-280z/
Well that makes finding a cap easier. The push button cap has been on there since I bought the car in the late 80s. I always figured it was the original cap as none of the receipts from the original owner showed it being replaced. I'll head over to the Nissan dealer with the part number on Monday to see what they can get. Thanks again, Jeff
  • Who's Online   1 Member, 0 Anonymous, 907 Guests (See full list)
