Start at the fuse block, clean the fuse holders, replace the fuses, then go to the headlight wiring harness themselves. Check the plugs in the wiring harness in front of the radiator for any corrosion and loose connections.
Check the wiring with a multimeter for the correct voltage. Check your ground wires in the engine compartment. Then if all else fails you will need to check your headlight switch itself. Take your time taking it apart and clean the contacts in the switch.
Hopefully you might find your problem before you get to the switch. It sounds like a fuse or fuse block problem but one never knows.....:ermm:
https://www.classiczcars.com/topic/3452-headlight-problem/#findComment-18073
  • Who's Online   0 Members, 0 Anonymous, 1,491 Guests (See full list)
