Site Updates this Weekend ×
i got a r200 diff from the junkyard. seems to be a really tight rear end. great shape.. i cracked the drain plug loose. and the oil that is in it is really really clean. but i noticed, its red. witch led me to believe it was atf. but after smelling it and rubbing my fingers thru it, it is for sure gear oil. has anyone ever seen a redish gear oil?
https://www.classiczcars.com/topic/34621-gear-oil/
