Help me fill in the console gaps
I purchased a 280Z console from Courtesy Nissan not too long ago to replace the mangled piece of plastic that was in my 260Z. There are two holes in the console that I assume would be filled on a 280Z. Could I get some feedback on what goes in them?
The first is the hole between the defrost and choke lights. The second is a big square hole to the right of the defrost and hazard switches.
Thanks in advance,
Steve
https://www.classiczcars.com/topic/34881-help-me-fill-in-the-console-gaps/
The large on above the defogger switch is the defogger indicator. The space next to it is blank and just has an empty insert. ( I suppose you could add a switch there). The big hole is also empty on mine. Check the picture and see if that helps.
Jan
