jasonparuta Posted November 5, 2002 Share #1 Posted November 5, 2002 I need a set of F/R side marker lights for my 73 Z. Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/ Share on other sites More sharing options...
2ManyZs Posted November 6, 2002 Share #2 Posted November 6, 2002 If you are looking for new ones, try Too Intense Restorations as they have them on their web-site and recently had them up for auction on Ebay.Or try Andy Russell at emailus@zcarsofarizona.comMSA might still have new sets also. Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/#findComment-18329 Share on other sites More sharing options...
EScanlon Posted November 6, 2002 Share #3 Posted November 6, 2002 The true 73 side markers had rubber boots attached to the rubber mounting pad. Sadly, these are NLA from most sources, (at least as of 4 months ago). If you are looking for 73 specific be aware of this as the 70-72 did NOT have the rubber boot covering the backs of the reflectors or the wiring. Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/#findComment-18340 Share on other sites More sharing options...
smg1404 Posted November 6, 2002 Share #4 Posted November 6, 2002 I will dig in my garage.... I filled in the holes for mine, and threw them back into a corner. I didn't want them, I thought they looked dorkey... If I can find them they are yours. Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/#findComment-18363 Share on other sites More sharing options...
andrew240z Posted November 18, 2002 Share #5 Posted November 18, 2002 I have the side marker lights that you are looking for. Let me know if your interested. Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/#findComment-19291 Share on other sites More sharing options...
kmack Posted November 19, 2002 Share #6 Posted November 19, 2002 Also keep in mind that the marker lights from the early cars will have different connections than the '73.I have a spare set (not in that good condition) that I tried to use on my '71 and the connectors (although both bullet type connectors) were different and would require a little re-wiring at the light to make work. Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/#findComment-19333 Share on other sites More sharing options...
GunnerRob Posted November 19, 2002 Share #7 Posted November 19, 2002 I replaced my front side marker light in my '75 Z about three years ago. I only replaced the reflector/socket portion with an early Z unit that didn't have the rubber boot housing.I mearly pulled out what I needed and inserted it into my existing boot. It fit perfectly and mounted in the fender correctly.I do remember having to futz with the wiring connection a bit but it wasn't difficult and I have no problems with it so far.Rob Link to comment https://www.classiczcars.com/topic/3492-side-marker-lights/#findComment-19353 Share on other sites More sharing options...
