Hello all,
Have just replaced my carbs with Ztherapy ones and have noticed that the carbs drain fuel over a couple of days and when I start the car I have to wait for the fuel system to refill.
I guess I have a leak and intend to put some newspaper under the carbs after starting the car from cold and then shutting off. if there are blotches on the paper then I guess I have found the leak.
However I was wondering if there is something else I need to check - fuel return system perhaps?
Cheers
Glenn
https://www.classiczcars.com/topic/3494-carbs-draining-fuel-overnight/
