The factory R180 out of my z (it has a non-LSD R200 in it) is absolutely caked with grime. Is there a specific method and/or cleaner that's best for getting all that off? Can the whole assembly be dunked in a bucket full of solvent? Perhaps I could have it hot-tanked?
https://www.classiczcars.com/topic/34989-best-way-to-de-gunk-a-differential/
How about... wait for it... Gunk.
You can put the diff in a parts washer or a solvent tank, but if you submerge it you'll get solvent in the oil. Not sure what effect the solvent will have on the seals either if that matters. I put my bare housing in my solvent tank and cleaned it that way before reassembly, worked great.
  • Who's Online   1 Member, 0 Anonymous, 1,318 Guests (See full list)
