Ok, today i noticed that the inner tie-rod ends where they bolt onto the
drag link are very close the the crossmember (infact it slightly rubs when i turn the wheel) i dont think it was like this before i rebuilt all the front end :ermm:
i think i could possibly have the idler arm bolted in the wrong position? it is in the middle set of holes, is this right?
is it possible i have the struts reversed??
https://www.classiczcars.com/topic/35119-240k-tie-rod-end-idler-arm-probs/
