OK, I am now running the 280ZX dizzy without the vacuum input. This is a good set-up. I get less or no ping under load than when I had the vacuum hooked up. Also, motor freely revs to 7K, which is great. No more 4K flat line. Afraid to take it over 7K as I think the tach has a slight lag and could be at 8K during a rev.
So I am doing about 75 MPH at 3K RPM. Theoretically I could do over 150 MPH in this thing before redline now. May have to try that someday to see what it could really do.
Do you have a timing light to check whats the current idle advance is? I would second Jon's recommendation to start with 18º and then continue from there.
What is your idle RPM right now? If its between 800-1000 RPM i wouldnt worry too much about it.
I have a european dizzy on order right now and I plan to add my experiences with it when I get it installed and dialed in. The main difference as far as I have been told is that the euro dizzy can run far more static advance as its centrifugal advance is much less than my stock 71 dizzies. I think it still has about 11 degrees of vacuum advance built in.
We will see,
my thanks to Walter Moore for the education on the types of dizzies I can run.
FYI, currently I have a stock 240Z dizzy with a pertronix unit with a flamethrower 3 ohm coil, resistor bypassed and running 5° BTDC. Basically just like Arne.
Edited by Zedyone_kenobi
Actually, I don't have a timing light. I have always done it by feel. I usually advance as much as I can until I get engine ping under load. Then I back off just a bit, so just a trace of ping under load. I plan on buying one some day soon here.
The idle is about 800-900.
Funny, last time I called Pep Boys for a timing light the youngster on the other end thought it was a device to turn your house lights off and on. We are dating ourselves here.
Go hit some pawn shops.There are screamin' deals to be had these days.
Just to keep this thread full of useful insight. I took out my gal for a spin last night, after being parked for well over a month. She had a horrible time getting past 5000 rpm. Two months before at a track day she screamed to 6500 with NO hesitation.
Certain things come to mind, as I did not change anything:
1) Ethanol, ethanol. I wonder if the gas is going south after sitting for well over a month.
2) I had a very low battery after sitting for so long, car barely started, and I noticed that my amp gage was reading very positive which to me means the alternator trying to charge the nearly dead battery back up. That low voltage may have been hurting my pertronix output
What I am going to do to try to solve this.
First the easy stuff. Check timing (that solved all my revving problems before)
Second, tune up, new plugs, cap/rotor, fuel filter
Third 60 amp alternator upgrade from MSA
Fourth, Fill up with fresh ethanol free gas
I will let you know of the results
if I keep putting these small projects in front of my tranny swap I will never get it done. But that is how these things happen :)
  • Who's Online   2 Members, 0 Anonymous, 582 Guests (See full list)
