Hello I found a supprise under my under coating and am not sure how to go about fixing. Should I cut out this area? How fare up should I go? There are two pices of metal the one is part of the fender sheet. The other must be a pice spot welded for a stiffiner. What is the thickness of the metal?
As you can also see my T/C mounts are very very bent up. Is this a avlable pice for replacement? I have only found fraim rails. They state they dont come with the T/C mounting brackets. Wow what was some one thinking:cry:
https://www.classiczcars.com/topic/35235-ware-to-start/
Hmmm, that looks vaguely familiar. Yes its a stiffener that is spotwelded over the inner fender sheet metal. I would hazard a guess that is 16-18 gauge. Maybe 20!
The TC "bracket" could be scabbed to - like what the factory did with that stiffener in your picture. BTW, Baddog floor rails weld right over the bottoms of the TC brackets.
Here is a link to one our members method of repair (has pics also):
http://www.classiczcars.com/forums/showthread.php?t=28644
Take a look at the pictures in my signature link for some oogly rust on a straight car. You might want to check out the rest of your rails.
https://www.classiczcars.com/topic/35235-ware-to-start/#findComment-314092
Wow that is a lot of rust
https://www.classiczcars.com/topic/35235-ware-to-start/#findComment-314218
Yup - its a good car except for the bottom 2 inches:mad:
Here is Zeddfindings for floors:
http://www.datsunzparts.com/
Here is Baddog:
http://www.baddogparts.com/index.htm
Here is a good bit of info on the both of them:
http://www.zcar.com/forums/read/1/1998011
https://www.classiczcars.com/topic/35235-ware-to-start/#findComment-314259
  • Who's Online   2 Members, 0 Anonymous, 1,393 Guests (See full list)
