Push up and down on the front end with the hood open. Watching the sway way while you do it. This should tell you if it's going to be an issue or not. If it is, Maybe a 1/4" spacer might help on the frame rail mounting points.
An increase in sway bar diameter should not cause a clearance problem. Although 1/4" spacers may help, I would take a close look for an underlying cause if its too close. It's not unheard of for distortion and weakening at the mounting points on the front frame rails or displacement of the frame rails even. Also, check the motor mounts for any bending or deterioration.
Edited by geezer
When I installed the larger sway bar, I had some additional welds done on the frame rails in that area. I also added plates under the mounts that extend beyound the mount holes to distribute the additional load from the thicker sway bar.
Maybe overkill, but I've read that big sway can damage the frame rails.
When I did my restoration back in '03 I found that my larger front sway bar was bending the frame rail and so along with the other parts we started making (frame rails, seat brackets, single point jack plates) we bend up a simple 90 with holes punched to match the frame rails. We sell them shipped to anywhere in the lower 48 for $30.
  • Who's Online   0 Members, 0 Anonymous, 1,541 Guests (See full list)
