richard1 Posted April 4, 2010 Share #1 Posted April 4, 2010 I have the driver's side ventilator that came off of its socket and I cannot fit it back. Is there a trick to put it back in place and being movable? Link to comment https://www.classiczcars.com/topic/35342-chrome-side-dash-ventilators/ Share on other sites More sharing options...
mlc240z Posted April 4, 2010 Share #2 Posted April 4, 2010 try here, I asked the same questionhttp://www.classiczcars.com/forums/showthread.php?t=37494&highlight=eyeball Link to comment https://www.classiczcars.com/topic/35342-chrome-side-dash-ventilators/#findComment-314929 Share on other sites More sharing options...
richard1 Posted April 5, 2010 Author Share #3 Posted April 5, 2010 I discovered that there is an inner hard plastic ring covered with some kind of felt. The plastic ring was cracked from age and desert dry condition. I used Loctite 404 industrial glue to fix it the crack. The ball is back in the socket and works properly.Thanks for the archive reference who solve the problem. Link to comment https://www.classiczcars.com/topic/35342-chrome-side-dash-ventilators/#findComment-314932 Share on other sites More sharing options...
