Posted
I was going to adjust the valves on my 70 240 I bought last year.
As a matter of course I checked the compression at the same time.
The first 5 cylinders were 185 to 187 psi at a warm to touch engine.
Number 6 was 160+ and the plug was white. Number 6 is obviously
running too hot. No oil in the water or water in the oil. I did a variation
of a leak down test and air came out number 4 plug hole. It doesn't
appear to be a head gasket (or at least the typical failure), but I am
not sure what it is. The valves did not seem really screwed up.
Anyone have any ideas? I would really appreciate it.
I noticed that my #6 plug is whiter than all the others as well. Is there any way to distribute fuel more evenly to this cylinder? I suppose richening the front carb would be the shotgun method.
