refurbish a stripped window regulator???
What part is stripped? The regulator is just a few pieces of stamped steel welded/pinned together. Would probably be less cost and work to locate another regulator that works than to refurb your existing ones. I haven't seen new-old-stock ones anywhere, but used ones are around.
Ill post pics later tonight, but basically the regulator is fine, its the part the handle hooks onto, the little grooves that the handle grips onto so it can turn and crank the regulator is stripped unfortunately. Pics to come!!
