I used this kit from Eastwood with some success on my original windshield. A previous owner had let the wipers (or lack thereof) create deep scratches in the glass. There were also a lot of pits as you've described. When I had my car repainted I bought a new windshield which unfortunately broke on install so we put the original back in causing me to try and repair it. I may buy new glass at some point anyway because even though the deep scratches are gone the glass is a bit "wavy" because of the amount of glass removed.
Since the kit is considerably less than a new windshield you could give it a try and if it doesn't work well enough you could go ahead and replace the windshield at a later date. It does work a lot easier with an angle grinder/polisher instead of a drill so you'll need to take that into account if you don't already have one of those.
If you literally have deep pits uniformly covering the entire windshield it would be an incredible amount of work. Like any polishing operation you're removing material (in this case glass) to reduce the entire surface level down to the bottom of the imperfection(s). I was less concerned about the pits from sand than the deep scratches from the wipers. I concentrated on the deep scratches (anything that you can feel will your fingernail). The deep scratch kit contains the colored abrasive disks which can remove a lot of material. The normal kit is a powder that is mixed with water and applied with a felt pad. It can remove shallow imperfections like hazing or acid rain etching, etc. There's a different product, which I haven't tried, which looks like another alternative.
  • Who's Online   2 Members, 0 Anonymous, 644 Guests (See full list)
