Just below the hood release latch in my Z, there is a black box with two white female end plugs coming from the unit. I found two different sets of numbers:
The first set was on a green tag:
Part #: All-600 000
Lot #: 6310
For: L28
The second, on a white tag:
Part #: A14-100 003
Lot #: 6211K
Is this thing the Engine Control Module? If so where do I plug those white plugs into? I can't find any other plugs that could reach there. If anyone has any advice that'd be really helpful! Thanks a lot all of you.
John
https://www.classiczcars.com/topic/35547-76-280z-ecm/
woah. mine has those too, and they aren't connected to anything. I'll double check tonite.
wonder what they're for.
i'd be sure they are good and insulated from the frame. one looks like it may have shorted to the frame at some point
(oh keep in mind mine is a manual)
Edited by AnthonyG
added transmission type difference
https://www.classiczcars.com/topic/35547-76-280z-ecm/#findComment-316565
Yes, that is the ECM.
I have the same wires, non-connected. 1976, manual transmission. I looked closely when I was working on mine and decided that they weren't meant to be connected to anything full-time and just pushed them back under the cover. I could be wrong. That was quite a while ago.
Maybe they are for diagnostics or a switch bypass.
https://www.classiczcars.com/topic/35547-76-280z-ecm/#findComment-316569
  • 3 years later...
An old thread but for posterity...Those wires are for the altimeter switch. CA models monitored altitude and would adjust the fuel pulse width if above a certain altitude. If yours isnt a CA model, the altimeter switch isn't there and the wires just hang.
Len
https://www.classiczcars.com/topic/35547-76-280z-ecm/#findComment-438715
The altimeter wires must be there somewhere for CA models, but the wiring diagram says the white hanging wires are Control Unit Checking Terminals.
I should have found this a long time ago, considering all of the time I've spent staring at the 1976 wiring diagram.
BUT. Looking at the 1978 diagram I see that there is an altitude switch. But its wires are black. The white checking terminal wires seem to be gone in 1978. I don't see them on the diagram or on a spare 78 harness that I have.
One more interesting thing. I've seen it suggested that one could put a switch on those altimeter wires and use it to get a lean tune. Maybe for highway cruising gas mileage.
Edited by Zed Head
https://www.classiczcars.com/topic/35547-76-280z-ecm/#findComment-438720
Zed,
The test harness I'm using for HellFire has white wires coming out for the altimeter not black. Go figure! That's why I assumed that the white wires from the OPs was the same. I have no idea what year this harness is from, it was just in a pile of them I had. Thanks for posting the pics showing the "Control Unit Checking terminals". I have never seen those referenced before.
I'll also double check my white wires to make sure they are in fact going to the altimeter switch.
Len
https://www.classiczcars.com/topic/35547-76-280z-ecm/#findComment-439143
