  • 4 weeks later...
Yokohama AVS ES700, P225/50VR-15. They're a little shorter then stock (23-7/8 v 24-3/4) resulting in a lower car and slight (4%) speedometer error.
If you don't want the car lowered, 16 inch rims would be the correct size with 225/50's.
WiZeguy,
Maybe. When I got this car it had so many issues; from the airpods, tight valves, misadjusted carbs, poor ignition - it's tough to tell what had the most impact.
But if we were sitting around having a beer, I would suggest that the air horns on the stock airbox would provide superior airflow at lower speeds as the air horns help to accelerate the air (venturi effect via Mr. Bernulli). Since I spend 90% of the time between idle and 4000 rpm, that type of performance is what is most important.
The pods might have an advantage at 5000 - 7000 rpms.
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
