The L26 and L28 crank is the same item.....look for a number cast into one of the crank counterweights. IIRC its N42
A diesel crank will be VO7
The L24 will be P30 IIRC
And heck, I can't remember what the L20A one is without popping out to the shed, sorry.
But I hope this helps. :)
That'll help. The reason I ask, is because I'm building an L24 (72). I bought the motor used, so I don't know the history. I put the bottom end together assuming all was original ( it didn't look like it had ever been apart) and when I installed the .040 over 240Z Nissan pistons, they came out of the deck by .035 inches. The machine shop decked the block .008 of an inch and assures me no more, but the piston is out .035 of an inch. I pulled a rod and they are 240Z rods. Is it possible someone had installed (by mistake) an L26-L28 crank?
Precisely. I honestly don't know enough about rebuilding to know what's acceptable but I knew you'd come to the inevitable conclusion on your own - as you've already done. All I was able to do was steer you away from the notion that it could possibly be an L26/L28 crank in there.
You're right about that! The number on the crank is E3141. I pulled a piston.....both rod and piston were L24 (long rods). I'll pull all pistons and dump this block in the garbage!!! It's beautiful with it's new paint and brass freeze plugs. What a shame! Guy
Don't waste the block!!!!!!!
There are 2mm (80 thou) and the like headgaskets out there that would solve your problem. Kameari make them, or you could find a custom thickness copper gasket that'll get you outa trouble.
What is the casting code on your block outa interest?
:beer:
As I understand it you can have the flat top of the piston out of the block by .015 with the stock gasket which crushes to .050 inches. The clearance needs to be .035 inch minimum. I believe that the gasket that MSA sells is for a bored out L28 and is 2mm. If anyone knows where I can get a 2mm gasket for a .040 over L24 I sure would appreciate your help. 2mm would be .080 less .035 out of the block would be .045 clearance. Thanks Guy P.S. It's a P30 block
Edited by Diseazd
  • Who's Online   2 Members, 0 Anonymous, 1,145 Guests (See full list)
