Just a guess from someone who typically doesn't do a lot of hot rodding, but since the stock SUs have two 46mm throats, and that even a pair of Weber DGV's is only considered to be stock replacement, I suspect that a single Weber with two 38mm throats would not be a performance upgrade.
https://www.classiczcars.com/topic/35653-intake-manf/#findComment-317442
It looks like the one you posted a picture of is from Arizona Z car, but it has a Holley bolt pattern and recommends using a Holley 390 CFM carb http://www.arizonazcar.com/manifold.html.
Here is one for sale on ebay now http://cgi.ebay.com/ebaymotors/1970-83-Datsun-Z-car-4-Barrel-Carb-Manifold-EC-NR-_W0QQcmdZViewItemQQfitsZModelQ3a240Q5AQQhashZitem3a5a4e37deQQitemZ250623178718QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories. Currently at $5.50 with no reserve and about 5 days to go.
-Mike
Edited by Mike B
typo
https://www.classiczcars.com/topic/35653-intake-manf/#findComment-317457
