Dan S Posted May 3, 2010 Share #1 Posted May 3, 2010 Well I've seached and running out of places. I have made calls here in Canada and the US for the front control arm bolts pn# 54436-E4100 and so far no luck, apparently NLA, I have tried Fastenal and Brofasco and have nothing. Any help would be great. Dan Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/ Share on other sites More sharing options...
zKars Posted May 3, 2010 Share #2 Posted May 3, 2010 (edited) Well you haven't asked me yet! How many would you like? I'm sure I have at least two extra's. Drop me an email to z240@shaw.ca and we'll get them on the way to you. Suppose you need the nuts too?Shocking that can't find 14mm x 85mm x 1.5 Gr 10.9 bolts at decent hardware supplier anymore. Jim Edited May 3, 2010 by zKars Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-318163 Share on other sites More sharing options...
Dan S Posted May 3, 2010 Author Share #3 Posted May 3, 2010 What blows me away is that we are supposed to be on the metric system for the last, ahhhhh, 30 or more years, and a place like Brofasco or Fastenal doesn't carry fine thread or a very "limited" stock of anything metric. Thanks for the offer, I will e-mail you later today, work called just now, they extra hands. Wouldn't happen to know where I can find 40057-21001 steering arm bolt found 1 in North America, 08124-04510 tension arm bolts need 4. I pulled the old and cannot fine a match yet. this is all I need to complete front and rear suspension. Dan Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-318175 Share on other sites More sharing options...
zKars Posted May 3, 2010 Share #4 Posted May 3, 2010 (edited) Dan:Metric supply sucks for sure. I've been tempted a couple of times to order things from McMasterCarr in the US after similiar fruitless searches in Canada.I'm sure I I have extras of the tension arm and knuckle bolts too. The only "specialized" Z bolt I've ever been able to buy at a Canadian bolt supplier is a spindle pin replacement bolt. They are 5/8 NF Gr9 x 10.5 or 11 inch long I think. Parts cars are heaven for sure, if you can find them.Jim Edited May 3, 2010 by zKars Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-318177 Share on other sites More sharing options...
pbarcher Posted March 26, 2011 Share #5 Posted March 26, 2011 I'm also looking for front control arm bolts for my 73. The p/n is 54436-E4100. Also need the lock nuts, p/n 08912-E4410 Nissan says they are NLA and BD and MSA don't have them either.Can anyone suggest where to find these?Thanks.Peter Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-350960 Share on other sites More sharing options...
JagoBlitz Posted December 24, 2022 Share #6 Posted December 24, 2022 Hi, can I get these bolts still anywhere? Alternatively, could someone give the dimensions of the bolts? It was mentioned that it tis a M14x85 bolt. What's the diameter of the cylindrical part and how long ist the thread? Thank you. Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648623 Share on other sites More sharing options...
dutchzcarguy Posted December 25, 2022 Share #7 Posted December 25, 2022 Maybe it would help if someone posted a picture with the dimensions? I don't have a clue what a "control arm pivot bolt" is. and where it sits in a front suspension... 😉 Europe has them for sure... i think🙊 Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648638 Share on other sites More sharing options...
dutchzcarguy Posted December 25, 2022 Share #8 Posted December 25, 2022 I could look in a service manual... 😴 Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648639 Share on other sites More sharing options...
JagoBlitz Posted December 25, 2022 Share #9 Posted December 25, 2022 Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648645 Share on other sites More sharing options...
SteveJ Posted December 25, 2022 Share #10 Posted December 25, 2022 https://zcardepot.com/products/front-lower-control-arm-bolt-240z-260z-280z 1 Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648646 Share on other sites More sharing options...
CanTechZ Posted December 25, 2022 Share #11 Posted December 25, 2022 (edited) 1 hour ago, SteveJ said: https://zcardepot.com/products/front-lower-control-arm-bolt-240z-260z-280z The image on the zcardepot web page looks like a DIN metric bolt that has an larger hex size on the head and the thread length looks longer. Originals are JIS metric with a 19mm hex size. The zcardepot ones I'm sure will fit, I just wonder if the overall length is adjusted to compensate for the longer thread length. Edited December 25, 2022 by CanTechZ 1 Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648650 Share on other sites More sharing options...
Terrapin Z Posted December 25, 2022 Share #12 Posted December 25, 2022 One issue with MSA's product, for $10 each set. $50 shipping Even a USPS small flat rate box is $42.00 to generic a Germany postal code. (I probably have some used bolts/nuts I could sell) Link to comment https://www.classiczcars.com/topic/35754-source-for-control-arm-pivot-bolt/#findComment-648651 Share on other sites More sharing options...
