If you can't find the OEM Nissan valve, try Bosch #0 280 140 124. It's a direct replacement for the JECS Air Regulator that Nissan used. Had one on my 78 280Z for almost the entire time I owned it.
Edited by sblake01
Great, thank you.
I tried Google on Bosch #0 280 140 124. Nothing came up.
Where did you get yours from?
Rockauto.com has it for $86
Fuel Injection Auxiliary Air Supply
BOSCH Part # 64402 {Auxiliary Air Valve}
You do not have to limit your search to just ZCars, ALL of the Fuel Injected, L-Series powered cars had them.
These do not go bad that often. You might start asking around to see if you can get a good one from another member.
Odd thing is, with warm temperatures here, there was no hurry! All it does is add air around the throttle valve. Its the thing that holds your idle up for a minute or so when the engine and air temp is cold. A wire heats up a bi-metal strip to close it off almost right away. You'll want it when we get a good cold front like the big one that hit in January...
  • 1 month later...
Is it bad to remove the air regulator completely? I only drive my car in the warm anyways, and the air regulator is getting in the way of my strut bar. If it is not bad to have the regulator removed, then I don't mind having rough idle until the car warms up, nor do I mind pressing the gas pedal a tad until it's warmed up.
  • Who's Online   2 Members, 0 Anonymous, 1,042 Guests (See full list)
