I've got a quick question, I'm ordering parts to change my oil on my newly acquired mostly stock 72 Z. I'm going with the Valvoline VR-1 10W-30, and I'm partial to Wix/Napa Gold filters, but the part number given for the 240Z is 51521 (Napa 1521), and my Z currently is running a Fram PH8A which is equivalent to Wix 51515 (Napa 1515)*. The difference looks to be only the capacity, any opinions or experience as to which one to go with?
Thanks!
*Edited to fix my own part number error
Edited by mec011
https://www.classiczcars.com/topic/35848-wixnapa-filter-number-for-72-240z/
Thanks!
Original Fram P/N was PH2850 when the L series motor was popular, the PH8A is for Ford products but seems to work fine on the L series motor
Almost every parts store will show the PH8A as the L-series filter, but it doesn't say it's an Only Ford item. I've been yelled at so many times about using Fram Filters, it's not funny anymore. So I guess I'll check out the Wix units.
I've read every "Fram Failure" write-up out there. But Honestly, I've used Fram PH8A's on my red Z for 7 years and NEVER had a problem. A filter is NOT a Filter if it doesn't do it's job but I've personally not had an issue thus far.
I'll try the WIX or Napa Gold and see if there is a difference. Not likely but I'll try anything once, twice if I like it.....
Finally your switching filters, now I have to find something else to give you crap about. ROFL
  • Who's Online   1 Member, 0 Anonymous, 1,297 Guests (See full list)
