Just go with a 215 or 225/50R16.
Fills the well, better sidewall for a smoother ride, wider foot print for better grip.
I have Eibachs and KYB's (soon to be Tokico HP's) 225/50ZR16's And there's no rubbing, great grip, smooth ride and they fill the well without any issues.
Dave
Pics below show how they look, plenty of clearance without looking too small.
https://www.classiczcars.com/topic/35876-2054516/#findComment-319391
The OEM tire, 175/78-14 has a total height of ~ 24.75 inches.
What you have asked about has a total height of ~ 23.25 inches.
The 175's have a sidewall height of 5.37", wile the 205's have a sidewall height of 3.63" - and they're much stiffer. The car ill ride like a skateboard.
215/50-16's will fit well and have an overall height of ~ 24.50 inches.
For what it's worth, I'm running 225/50-15 (just under 24 inches). The ride is stiff and the steering is heavy at parking lot speeds, but they do look good.
https://www.classiczcars.com/topic/35876-2054516/#findComment-319393
Here's one of many tire size calculators on the net that will help you determine the diameter difference (and resulting speedometer error) of various tire/wheel combos:
http://www.miata.net/cgi-bin/tirescgi
Oops, tried to post URL of results page instead of original page:
http://www.miata.net/garage/tirecalc.html
Edited by MikeW
bad URL
https://www.classiczcars.com/topic/35876-2054516/#findComment-319401
  • Who's Online   2 Members, 0 Anonymous, 1,256 Guests (See full list)
