askgeorge Posted May 18, 2010 Share #1 Posted May 18, 2010 I have a 72 Z that I bought new from PaceSetter in Rochester. It has 242,000 on it. About a year ago I overheated it and it started blowing blue smoke. I figured I had melted the valve seals so over some time I got a rebuilt head and replaced it. Got it funning and it still blew smoke so I figured it need the bottom looked after. had arranged to take it to a place for the rebuild but now I can't get it started. Everything seems to be normal up to the started motor starting. So, I have: Charged/checked the battery OKI have taken the started motor to Kragens for testing OKI have replaced the starter switch (not the key part) OKI have replaced the coil OKI have changed the ballast resistorI have checked the starter relay.So, when I try to start it, when I turn the key in the Acc. position all is ON and the radio comes one. When I turn to ON, the starter relay clicks. When I turn to start the relay clicks again but nothing happens. It is an automatic so I have also tested that switch too OK. The coil wire to the distributor is intact. I am at a loss. Any ideas would be appreciated. Link to comment https://www.classiczcars.com/topic/35939-befuddled/ Share on other sites More sharing options...
Oiluj Posted May 18, 2010 Share #2 Posted May 18, 2010 Try cleaning the battery terminals and checking the starter cable / ground connections. You can have a good enough connection to run low wattage items, but not turn the starter. Link to comment https://www.classiczcars.com/topic/35939-befuddled/#findComment-320164 Share on other sites More sharing options...
hogie Posted May 18, 2010 Share #3 Posted May 18, 2010 Are you getting power to the starter solenoid when you try to crank it over? Link to comment https://www.classiczcars.com/topic/35939-befuddled/#findComment-320171 Share on other sites More sharing options...
