Idle, Sneeze and Smell... Are they related??
Im new to the forum sorry if anyone finds that fact annoying...
I need help with my Z thats driving me a little nuts.
My Z has this sneeze that wont go away,
Ive replaced my distributor rotor, spark plugs, plug wires, adjusted my spark timing and replaced my air flow meter. Nothing seems to make a difference BUT all parts were messed up in one way or another.
Ive been following specs from a haynes manual (spark gap, timing):stupid:
After driving the engine smells like charcoal and burning plastic.
My Idle is usually high (1200-1300rpm) when i adjust the throttle screw to idle around 900 and turn off the car, the next time i start it it will be at approx 400. Also during driving I will get Fluctuations of 800 to 1300.
Im at a point where i just feel like throwing parts at it blindly because they all need to be replaced anyways hahah. Does anyone know if these 3 problems could be related? Any Ideas?
Current plan is to replace the horribly old looking Air Regulator, Throttle position sensor and all vacuum lines.
Thanks for your quick response. I have contemplated vacuum leaks as all the hoses look pretty f'd i didn't consider throttle linkage and will do some cleaning this weekend.
The reason for the new post is I am wondering if these problems could be related. The strong charcoal smell and Intake backfire are most likely related. Probly have 2 separate issues.
Thanks again for your time.
  • Who's Online   1 Member, 0 Anonymous, 1,300 Guests (See full list)
